LN Pipeline
The fuel shut-off solenoid on an 8.3 cummins is activated by two of these solenoids.
One for PULL, and one for HOLD. The PULL solenoid quit functioning, so I purchased another one (Cole Hersee 24063). The new solenoid worked once, then quit working. Got another new Cole Hersee, and same thing. It worked once, then quit working.
I took the old good solenoid off the HOLD wires, and wired it to the PULL wires. It worked fine. Activated it probably 2 dozen times to see if it would burn up.
I purchased a NAPA ST93 solenoid and installed it on the PULL wire. Unplugged the fuel solenoid on the pump to make sure it was not the culprit. The NAPA solenoid won’t activate at all.
The 12V activating wires light up when they are supposed to, and no shorts. The 12V activating wire for the PULL solenoid also activates the starter solenoid, and the starter solenoid works fine. The 24V wires have no shorts and share the same terminal at the starter.
Does anyone have any idea what’s going on here? It seems like I got three faulty solenoids since the old one on the HOLD wire worked fine when swapped.
Is there a better option for a 24V continuous duty solenoid?
