JNewton
I have a 2000 Genie lift Z45/25J DC will not drive in either direction. The machine is all electric over hydraulic and the drive motors are electric and have hydraulic release brakes. The machine was working fine and now will not drive in either direction. Motor controller is providing code 34-
Fault Code Programmer Diagnostic Display Condition Possible Causes Solution
34 -
MISSING CONTACTOR Machine will not drive. Motor controller does not detect the main contactor PR1 or brake release relay CR5. Consult Genie Product Support.
MAIN CONT DNC Machine will not drive. Main contactor PR1 or brake release relay CR5 did not close OR open in org/red wire to PR1 and/or CR5 OR main contactor and/or brake release relay is defective. Consult Genie Product Sup
As per the manual.
I have tested the motor controller and it seems to ohm out properly.
Any help appreciated- thank you
34 -
As per the manual.
