Billy B.
Hello, I'm new to this site and hoped someone could give me advice on why the secondary boom on a Genie Z45/25J won't come down. It will go up but will not come down using either the ground controls or the controls in the basket. This boom has 2 hydraulic cylinders that raise/lower it with two connecting hoses between the two cylinders. When I toggle the switch I can see the one hydraulic hose leading to the cylinder "stiffen" for a brief moment but nothing else happens. All other cylinders work fine. Since both of the hydraulic cylinders to the secondary boom have counterbalance valves, I'm guessing that that is where the problem is. Has anyone else had this issue? An additional concern is that the basket is 20' in the air and I worry that if I remove one of the counterbalance valves it'll come crashing down. I would certainly appreciate any suggestions. Thank you, Bill
