I have a 1987 Grove at400 with PAT ds350g lmi with an error code E07. When I looked up the code it's for a bad relay but the problem is I can't find a new relay. There are two relays in the lmi and if I swap them the code changes to E08 which is a code for the other relay being bad, so it does seem as though the relay is bad. The closest thing I could find for a replacement relay was 3 old untested relays off ebay for $10 so I tried them but they didnt fix the problem.
I know these are becoming obsolete but just thought maybe someone on here might be familiar with them and know where I might look for a replacement relay. I did try calling Bode Tech but the guy I talked to wasn't able to help me. I also considered that maybe there's a problem in the board and the relay is fine but the code moves with the k1 relay.
