Here's a question for you. If I have the boom down so it's parallel with the ground, can I use the hoist to pull horizontally? I would think not, but thought I'd ask. This would come in handy if I was trying to unload a big crate from an enclosed trailer and I used the crane hoist to pull the crate out to the liftgate so I can lift it traditionally. The crates would be perhaps 3,000 lbs at the most. I was planning on attaching a cheap harbor freight winch to the front of the crane to do this but if I can use the main crane hoist that would simplify things.oops! I read it.
Yes you have 8800 maximum pull on that winch and it will probably be smooth through ~5000.
Most of the time you will want single part.
I googled it and it looks like OSHA prohibits using a crane to drag a load.Here's a question for you. If I have the boom down so it's parallel with the ground, can I use the hoist to pull horizontally? I would think not, but thought I'd ask. This would come in handy if I was trying to unload a big crate from an enclosed trailer and I used the crane hoist to pull the crate out to the liftgate so I can lift it traditionally. The crates would be perhaps 3,000 lbs at the most. I was planning on attaching a cheap harbor freight hoist to the front of the crane to do this but if I can use the main crane hoist that would simplify things.
