Greetings,
Was on a worksite (my first big job of clearing and grading 1 acre for a home build), when all of the sudden my compact track loader started to sputter stall intermittently now it seems to be permanently derating. Here are the codes that are coming up on the to 2018 Yanmar T175 with the 4TNV98C (Same as the Gehl RT175). I don't have a troubleshooting manual but I found one online and next to the fault I wrote in the fault description from the manual:
157-16 "PLV open"
523470 "Rail Pressure Fault (pressure to high)
523489 "Rail Pressure Fault (time of opening error)
I figure something must causing the pressure relief valve to pop off and perhaps it was the SCV? I was able to do a search here and find someone with an excavator having a similar issue but they had 3TNV and mine is the 4TNV. Wondering if perhaps the SCV (suction control valve or regulator) valves are interchangeable? Also if I change whatever part is the root cause will the code clear on its own?
Thank you to all for any wisdom.
157-16 "PLV open"
