Msh2
I have been working on a JD 450J (s/n T0450JX139324) and have had some help from this forum.
Engine starts but won’t throttle up and won’t move. One suggestion is that the decel sensor may be stuck. I took some readings and didn’t see any changes as I depressed the pedal. Got a new sensor and had the same results.
Read a post from Sep/oct 2023 and am seeing readings measured in volts, not ohms. .
What is the routine for determining if a decel sensor is bad?
Thanks
Thanks
