Championized
The hyd. fan is running at top speed as soon as the engine is started, even when cold. I've disconnected each sensor (charge air, rad. intake, and hyd.) one at a time, but with no effect. If I disconnect the fan control unit the fan returns to normal speed, but I don't believe this proves it's the fan control. I suspect it could still be in the ECU. Has anybody else had this problem and if so, what was the fault?
Thanks, Steve
Thanks, Steve
