That is probably the case... but are these two cranes not the same exact one? if so then it is a Krupp. but i know very little about cranes so...:beatsme
The old GMT 8250 Krupp is unmistakeable ..
this picture is the Krupp KMK 6250 or the KMK 6275 ..the 250/275 were pretty much the same crane ..but ....right of the hop my friend you have an extra axle over the first picture ..
This is a Krupp shown here..reason ..4 head lamp system,says Krupp in the counter weight ..
notably on the upper ..is that little step at the front of the upper superstucture,thats where the swing motors are as well as the valves to set the free swing for road travel ..
Also notice the tubes welded down the side of the heel section inside one of these the air lines for the boom dog's were run to the hose reels ..as well as some electrical ..Krupp
Krupp had 2 aluminum ladder's
on the deck that turned out and pivoted down ..to use ..they were not built into the carrier fender's,
there were two ladder's mounted center either side in the carrier fender ..its also where the outrigger controls will be found .. for a total of 4 ladder's..
Notice the Krupp has no mount for a swing away ..because that it was an option on the 250/275 ..that crane in first photo does ..
That first photo ...Out on a limb here ..but if you get closer and ask ..I'll say its a LTM 1160/2 Liebherr.... It may get refered to as a 190 Liebherr .. On the high end a 200ton...
