hofdoug
I just bought a JCB and the all wheel steer mode does not work,I put in a new switch but it still will not work fuses and relay are good, any ideas?
Is there a adjustment on the sensor or did you buy a new oneThank you thank you thank you all how have replied the front sensor was to far away.
Way to be over dramatic. 9 times out of 10, the problem is the proximity switch on the axles.For your sake I was hoping you wouldn't buy it.
There's not much to the steering system. A switch, computer, two proximity sensors, and a small manifold with a couple solenoids to divert hydraulic flow. I don't know how he spent 5400.Over dramatic ?
I don't think so.
Piston spent $5400.00 on his JCB.
No way in h@ll would I buy a tractor with a screwed up steering system on the chance it is just a switch.
