Hopefully the experienced here can help me proceed without causing any further problems. I fired up the backhoe after an inactive winter and although I checked the oil and hydraulic fluid I forgot to check the coolant. I was moving material around and grading for a few hours and thought it seemed to be running hot but was stubbornly trying to wrap up what I was doing. Anyway as I was shuttling one of the last loads I heard a release of pressure and a good amount of whitish smoke came from the engine compartment. The engine cut out at the time of the pressure release.
When I opened the engine compartment the dipstick had shot out of its tube. Of course then I checked the coolant and it was very low possibly empty. I checked the oil afterwards and the level is full and appears normal not milky that I can tell from the dipstick.
My plan was to drain the oil make sure there is no sign of coolant in there and if not change the oil and filter. Flush the coolant system and refill. Then start it back up check for leaks and get back to work. Does this sound like a reasonable way forward or any other ideas.
