jboettcher
I have a 555A John Deere. I rebuilt the right finale drive that was leaking. Pushed good but leaked oil. All the seals and bearings were junk. When I installed I "did not" tighten the set screw on the splin/shaft that goes into the the clutches. Now it does'nt leak but it also does not push on the right side. I was told that I had proberly let the clutches slide back and ruptured the hydrulic line which pressurises the right clutches. I have started to take off the fuel tank so I can get to the top of the right side. I'm hoping to find that line cut and a simple replacement. Has anyone run into this before and any words of wisdom for me as I tackel this problem?
Myassitis
Myassitis
