Toddgarage
- Joined
- Jun 13, 2022
- Messages
- 80
- Location
- S.E. Michigan
- Occupation
- Construction, welding/fabrication, operator
Working on a JLG boom lift 340 AJ. It developed this issues rather abruptly. The brakes will not release at low or mid engine speeds. If you select full engine speed, the brakes release enough to travel the machine in either direction. At low or mid engine speed the brakes drag enough to cause the tires to visibly shutter, but the drive motors can overcome the brakes enough to move. Here in Michigan it’s cold, and this problem happened outside last week while working. As the hydraulic temps warm up, the brake issue gets worse.
I’ve done a solid 2 days of diagnosis and trouble shooting. Including a very helpful phone call with a tech from JLG who was very knowledgeable.
Details:
1625 hours, Kubota diesel, H1 S. Danfoss main pump, clean hydraulic fluid.
Charge pressure from port M3 is variable with engine speed. It’s 100psi at idle, 200psi at mid rpm and 350 at full throttle. The brakes only released at 350psi.
Tested pressure at brakes, it also varies with engine speed. JLG tech says charge pressure should be 375psi all the time. Small adjustments to the charge pressure adjustment screw don’t make significant changes to the pressures.
*Removed the charge pump filter and found small green debris in it. Soft, not pipe dope.*
In the diverter valve (aluminum manifold assembly in undercarriage). I have replaced the spool o-rings for both the brakes valve and traction lock valve. Checked coils for voltage and ohms, this looks good. The oscillating axle cylinders also don’t seem to work. These are supplied hydraulic pressure from the same diverter valve block.
The JLG tech is hinting at a bad charge pump in the main hydraulic pump. The variable pump is used for the 4 wheel drive motors, which work. There are 2 additional auxiliary pumps mounted on the main pump.
Has anyone had a similar issue with their pump, brakes or hydraulic system on their boom lift. The debris in the filter… maybe a seal was blown out by excessive pressure during cold operation?
Thank you fellow mechanics!
Details:
