hillside876
Hi, hopefully, someone else had a similar experience and can give me some guidance. I have a 1993 644G loader with about 9300hrs, The Unit works fine under light load for a longer period. Once the unit starts working and the transmission oil indicator gets to about 1/2 or a little above the warm markings the park brake light comes on and locks the machine. Once the transmission oil cools, I can use it again until the oil warms up. I'll list what I've tried below.
- Change Transmission oil and filter
- Change the Oil Cooler Filter
- Clean the oil cooler with low-pressure water
- removed the thermostat from the bypass valve
