Had a new John Deere delivered this week and we are having problems with it, the dealers mechanic seems a little unsure as to what is wrong.
The blade lever works fine when the machine is not running, nice and smooth just like it should be. The problem starts when you put it to work, when angeling the blade the lever does not return, then the same happens with the lift and the tilt.
The mechanic played with it some but then it started leaking oil from around where the linkage goes into the valve block. Their are retaining rings around the linkages as they go into the valve block and they have all lifted (bent upwards) on the one side.
Has anyone out there had a similar problem and know what the answer is, I am thinking a new valve block?
