RPRZEN
- Joined
- Aug 27, 2020
- Messages
- 16
- Location
- Charlotte, Texas
- Occupation
- OILFIELD, CONSTRUCTION, RANCH EQUIPMENT TECHNICIAN
HELLO ALL,
I HAVE AN ISSUE WITH A JOHN DEERE 850J DOZER. THE HYDRAULICS LOOSE PRESSURE WHEN LIFTING THE BLADE TO FULL STOP AT OR ABOVE 50% THROTTLE. ONCE THAT HAPPENS IT WILL LOWER BLADE VERY SLOWLY AND NOT LIFT AT ALL. IT IS LIKE THE PUMP OR CONTROL PRESSURE IS DERATED FOR SYSTEM PROTECTION. IF THE ENGINE IS SHUT OFF THEN RESTARTED IT IS BACK TO NORMAL HYDRAULIC SYSTEM PRESSURES UNTIL THE CYLINDERS REACH END OF TRAVEL. DOES NOT DO IT BELOW 50% THROTTLE ONLY AT 50% AND ABOVE. I HAVE ABSOLUTELY 0 SERVICE INFORMATION ON JOHN DEERE EQUIPMENT. I DID DO A GOOD LOOK OVER OF THE MANIFOLDS AND PRESSURE XMITTERS. I DID FIND ONE PRESSURE XMITTER RIGHT NEXT TO THE CAB JACK THAT HAD A BROKE WIRE AT THE DUETSH 3 PIN CONNECTOR. I HAVE A CAT DUETSH CONNECTOR KIT AND I BUILT A NEW CONNECTOR PIG TAIL AND REPLACED THE DAMAGED ONE USING CRIMP N SEAL BUT SPLICE CONNECTORS. BUT OBVIOUSLY IT DID NOT FIX THE ISSUE. ANY ADVISE OR SERVICE INFORMATION ON THE HYDRAULIC SYSTEM WOULD BE MUCH APPRECIATED. THANKS IN ADVANCE!!
