- Joined
- Jan 21, 2007
- Messages
- 14,589
- Location
- Alabama
- Occupation
- Running what I brung and taking what I win
As for the steel box, it came with a bunch of steel chokers, from a auction years ago. It's made me more money than probably anything else I've bought.
We use it mostly for commercial roofers. All their tools/trash/materials from the ground to the roof and back. I've got a fancy one now , with a hydraulic dump bottom, that we use for trash, but this one has given good service.
It originally had a steel bottom on top of the forklift pockets, but it was all torn up when we got it. I cut it out and put in 3/4" marine plywood, and just put in new plywood when it gets bad. If you want to dig out of it, you would need a steel bottom.
Sheet steel, angle iron, and some square tubing for the forklift pockets, and you'll be set. This one is roughly 4'x8' x 12" tall. You could put a arm and bar on it, so you can move it with the excavator bucket, just like the big bedding boxes.
I need to start back perusing IP and see if I can pick up one. Probably wouldn't want to mimic a big one with a pull/lift arm as the mini probably wouldn't have enough ass to pull it much less lift it.
Fork pockets would suffice since the CTL's are constantly going from bucket to forks.
