Kobelco 115SR underperforming is it mode problem
jjfpuru
uk EX36 4QY
My Kobelco's mode selector is not reporting its selection I think it is stuck in S. Can someone explain what parameters it changes?
For example when s is selected and you take a big bite of earth will it prevent full pilot presure being applied to the squash plates and therefore not ask the engine for more torq or will it increase pilot pressure but not let the engine respond. Will either of these paths present as if the main pump/engine is worn. My dig functions well, slew has no strength and on a heavy dig the engine does not grunt and the bucket just stops untill the boom is lifted a touch.
KOBE STEEL
If you are finding that the mode selection is not being displayed on the monitor and assuming you have a -1 model then you may find that the lamp bulbs in the display monitor are blown otherwise the S mode is usually a standard digging mode selection which should not underperform or be restrictive for digging and slew operations, I would think that this may be another issue you are having.
Kind regards
jjfpuru
uk EX36 4QY
Thanks for your comments it looks like the fitter did a good check i have attached a screen print if you can read it and maybe comment?
Meanwhile I have been offered a new Korean bare pump for £2500 which I think is as good a prospect as any.
Thanks for your helpful advice will go and check those bulbs now!
Regards
KOBE STEEL
You need more diagnostics carried out before committing to replacing the pump. The pump units are positive proportional controlled and require a pilot supply pressure to both regulators to function correctly. If you would like some help carrying out your own diagnostics checks them pm me and I can try and help you where possible.
The pump brand is Kawasaki KPM and there is a Korean manufacturer that makes aftermarket pump parts and complete units for just about every known machine brand on the market. While the finished product looks identical to genuine, some of the parts have major flaws, so exercise caution when purchasing complete pump units or base units at a low price. Flutek is the official Korean engineering company that manufactures Kawasaki hydraulic components and pump units with most of its share holdings now owned by Kawasaki Precision Machinery Japan.
jjfpuru
uk EX36 4QY
Help would be great but I don't appear to have the exact manual for my m/C
The gear pump in my parts book shows a filter on the poppet but my pump looks different.
Also in any of the modes a 360 turn in any dirction takes 24seconds if i put the KPSS to release the turn takes 11 seconds each way.
Just had a splash on the monitor as I shut down
"CPU
MECHAIRO
CONT FA"
I had been switching between modes just prior to shutting down.
So maybe the control panel?
I have found manuals for Kobelco SK1155-1ES, SK135RLC-1ES, SK135SRL-1ES Excavator - Workshop Manuals
at £10 these may be a scam but not a big risk?
Will check the manufacturer of the bare pump I am being offered.
Many Thanks
KOBE STEEL
When the display monitor loses communication from the main controller it will display CPU MECHATRO FAIL. It is not uncommon for these controllers to fail. The main controller is located behind the seat under the speaker panel. Switching the KPSS switch bypasses the controller to send a fixed electrical current to the pump solenoids so the machine can still be moved for emergency situations. Any issues with the main controller must be rectified prior to carrying out any additional diagnostics.
See down load link below for Kobelco manual which was posted by well known Forum member "Lachau". So all credit to Lachau, Thank you !
"https://www.mediafire.com/file/ctkbpwncbzkpj7a/SK115-SK135SR+Shop+Manuall.pdf/file"
Kind regards
jjfpuru
uk EX36 4QY
Got the manual so great.
I am suspicious of the controller and will check all connections but if no luck then start to look for replacement controller.
Unless I can get a pre-used controller the programming is beyond me, and probably to expensive to get proffesionals involved on such an old machine.
The KPPS switch bypasses the controller so if I reset/raise the pilot pressure the KPSS switch is using could I get a constant performance based on throttle setting or maybe fix the electrical current the KPSS is sending to a higher level, is it just a voltage? All just really inefficiently but i will only use the m/c a couple of weeks a year.
Regards
KOBE STEEL
The controller operates a number of solenoids for single and combined operations so if the controller is giving you issues you may find that operating the machine in the KPSS release state is difficult with certain movements and operations. Do not raise your pilot pressure above factory setting, this will only create more heat and accelerate wear to the pilot pump and may damage your pilot system controls and sensors. Changing the electrical resistance may also damage the pump solenoid coils if they draw to high and operate outside its limits.
Getting another used controller that suits your machine model would be your best solution. To help avoid any additional breakdown costs try changing the hydraulic oil and return filter yourself and keep the radiator and oil cooler clean and clear of dirt build up. Keeping the oil cool and clean goes a long way in getting the most operating hours from your machine with fewer breakdowns.
Kind regards
jjfpuru
uk EX36 4QY
Hi sorry for delay have managed to check my first thoughts and sure enough 360 turn under normal operating take 24 seconds with KPSS release takes 11 seconds.
Monitor says all ok and can get information out of it no mode indicator on display.
Can you advise a supplier for a YN22E00069F7 replacement does it need to be an exact numerical match and does it need programming and to do so will there be software required?
KOBE STEEL
Correct part number is important. It will require a step motor calibration procedure. Once this is done then the screen should display as normal. Depending on the supplier you may have to provide a serial number for preprogramming by the supplier.
Here is a possible lead.
jjfpuru
uk EX36 4QY
excellant again.
just suppling engine details for them to be able to preprogram before quoting me!
just not sure the problem is the controller. I am basing my thoughts on the speed increase using KSPP release switch and lack of reporting/change of mode indicaton. The menu reports all other parameters ok. Would the controller report KSPP switch operated or fault on monitor I wonder?
Can I do a step calibration on this controller or do I need some software?
jjfpuru
uk EX36 4QY
ahh
just found screen 22 on the service menu should show is KSPP is operated so maybe mythoughts on reliability of the controller are rubbish.
Any idea how the controller can be checked out.
If the suppliers come back witha sub £600 replacement price I guess it should clear it up and then I can concentrate on the pump issue?
KOBE STEEL
here is some information from a -6 training manual and although it is does not cover your specific machine model you can still use this as a rough guide for doing checks and reading values off the monitor. You can use the check sheet to record your values. Out of range readings can suggest an issue with wiring or a faulty sensor or solenoid, most sensors when out of range are usually picked up by the controller and an error code is given.
For the step motor calibration, this should be in the manual, see link in previous posts.
  • Binder1.pdf
