willie59
Static voltage on a 12V wet battery is 12.6 volts since each cell has 2.1 volts, 2.1 x 6 (cells) = 12.6. And that may vary depending on battery condition, but is not a finite indicator of battery condition. Load is better indicator of condition as you can have a battery, and Gagu has done a sort of "load test". Stated he had a static voltage of 12.7, but wouldn't crank (load). Boosted it and started right away. Perfect example of failed battery that has proper static voltage but fails under load. Battery has gone south.
