3rdgendslmech
I'm sure we've all been in a position at some point in our career where the boss or company owner wants their equipment up and running ASAP.
So a couple years ago the company I work for purchased a spare transmission for our 4 D8N tractors that we use to push up deicing salt.
It takes me and another mechanic 6-8 hours to do a swap out, vs a week + waiting on parts while the machine is down.
About a month ago a transmission in 1 D8 goes out ( 1st gear clutch pack worn out and would push ), I swapped it out, changed filters, screens and sent it on its way. Been running every day since with no problems.
Rebuilt the transmission that I pulled out and about the time I was going to set it into a storage box, a different D8 loses its forward clutch pack. Pulled the screen out and found rubber that had gotten hot and stuck to the screen filter in the bottom of the transmission. Different mechanic took this job as I was busy working on trucks that week. He did the same thing I did, swapped the transmission, flushed the system and power train oil lines, rebuilt the trans. control valve, changed filters etc etc..... A whole 12 hours later what happens??? No forward in any speed. Right away all fingers get pointed at me because lets face it I rebuilt the transmission. So I go take a look real quick in between working on trucks and find the screen once again packed full of melted rubber. So now I take on the task of figuring out "did I miss something somewhere" or is it "operator error" or maybe the other mechanic missed something.
Well this particular D8 is a 5TJ serial # and the other 3 are 9TC serial numbers so the main difference in the transmission is that the priority valve is mounted on top of the frame above the transmission instead of being bolted to the control valve of the transmission itself. Started with checking pressures before I pulled the 2nd burnt up transmission out, brake release pressures good on both sides. Pump pressure good. Speed and direction (other than FWD due to blown clutch piston seals) good. Trans lube pressure good. What isnt good......priority valve pressure....FML :Banghead At an idle i had 380 PSI, cat recommends 420 give or take 20. After about 15-20 minutes of doing other tests, a phone call and what not priority valve pressure is only reading 100 lbs.
Come to find out that a 3 dollar o ring on a check valve had blown and started dumping oil caused the death of 2 transmissions. Now I know some companies have procedures when doing rebuilds as far as setting and checking pressures after repairs. But when the owner says he wants it up and running by morning, you kind of skip a few steps. Turns out this one cost him about 2K in parts plus my time.
