I have a 580 SE with the cummins engine. Fuel is spraying out of the tach drive cover. I asume? the injector pump has blown a seal as it's right behin d the tach drive. I pinned the drive gear as per the manual, and need to remove the pump itself from the drive gear. Does anyone know the thread, diameter and pitch of the bolt's for the "gear puller" to attach to so I can push the shaft from the gear? I'm guessing 8mm X 1.25. Looked into buying the tool and it's a month away, so I'll be making my own. OR can I tap the shaft out with a hammer? How delicate is the injector pump?
Thank's for your time/help.
