paulinkansas
![20160222_143141.jpg 20160222_143141.jpg](https://www.heavyequipmentforums.com/data/attachments/135/135715-4c9f823d87020fa2a7e05596d33d4a10.jpg)
Dozer sat for a few months. Had no power when I started it. Rats had chewed some wires to what I presume is the fuel pump. Is this the fuel pump?
The wire at 11:00 shows 24 volts when the key is on.
I presume the above wire goes to the wire in the 7:00 position. It's insulated about 1/4" all the way around.
The other two wire stubs in the 1:00 and 4:00 seem to be grounds.
Would I be correct to solder a jumper from the 11:00 to the 7:00 wire?
I'm not sure what to do about the others. They are non insulated connections.
