big builder
Hey everyone,
I have an FL5 that is a bit fussy.
I don't have any manuals for this machine. Can anyone confirm that it is dextron ATF in the transmission? Will type 2 or 3 work as well ( I already have some)
Also it seems to lack power when backing up. IF I am going up a grade it really kaffs out. Seems to be good and powerfull going forward.
The only other thing is that is seems to sputter a bit when running. Just a bit of a miss at all engines speeds. It smokes a light blue smoke pretty much all the time, the smoke is very acrid I find compared to all the other diesels I own.
Anyone with experience can let me know about what throttle position they find works the best on the machine. I run it sometimes at about half throttle
and it's a little weak but at full throttle is pretty noisey and jerky.
Has about 30 - 35 psi oil pressure at full throttle is that in range?
Thanks for everything
