MultiQuip Hog Crusher???????
mike s
Columbus Ohio
Excavating/Snow Removal
Does any one have any input on this attachment? Im Looking really hard at this attachment and have not heard anything about it. Im not looking to open up a recycle plant but to use it on small demo jobs and other stuff like that. It would be nice to have this at my shop on a rainy day also. Even if no one has input just some thoughts on what you guys think would be good!!!!
KSSS
Idaho
excavation
I looked at these at ConExpo and it probably has a place, if I recall its production rate was around 10 tons an hour. Thats not quite a dump truck per hour. I was not exactly overwhelmed with that. Considering that rate is likely under optimal conditions, it would take a while to process material. However I have not heard from anyone that actually has one either, maybe their are more productive than the numbers would suggest.
mike s
Columbus Ohio
Ya your not going to make mountains of material but I was thinking of putting this attachment on my 864 and feeding it with the rc30. Alot of the work I have right now is tearing out old concrete in very tight places. Most of the concrete is old, broken, thin, and junk. I hope I wouldnt over run the attachment with the asv! LOL!
Yellowdog
what does something like that run? Could find a multitude of uses for it where I live. A rock crusher attachment (like a brush mower for rocks) is about 30k..
KSSS
Idaho
excavation
I like the idea of these smaller crushers. I think that at some point the cost of fuel will make onsite material processing more profitable than trucking old material out and new material in. I am would be curious as to what the anticipated cost per hour that skid steer attachment runs at.
Bumpus
Florida
Disability / Retired
I might be possible to buy the crusher and mount it on another peace of equipment, or even on a pick up truck or pull trailer, with a different power source ( motor and pump )
Yellowdog
I've been thinking more and more about this. I do about 30% of my work doing driveways and site pads. Nothing fancy, just crushed base or doing rehab on an existing road. I clean out ditches, grade caliche roads, and in the process, pull up a lot of rocks. Our limestone is endless.. I live on a virtual rock farm. About 15 years ago, I would use a Rockhound to pick my fields and trails clean. I loved that attachment but it was flimsy and high maintenance if you hit a rock over 6". It was amazing, though.
Looking at that portable hog, I can see it having it's place if it could be used like a bucket to scoop up oversize rocks after grading a road or cleaning the drains. I envision spreading the material (crushed and mixed) into low spots, then running the compactor over it. Since a lot of old ranch roads are made of caliche that gets soft when it rains, mixing rocks on top like would be a good way to make the roads all weather. I can also see this being used to lay a gravel course before putting down 3/4 crushed base which I've found usually needs something hard under it. I want to get into demolition more, too, and crushing rocks, cinder blocks, and bricks would be interesting. If I work with a small trucking company, 1 or 2 trucks, and a lot of my jobs are in tight spaces anyway, I am only getting about 13-26 tons an hour out of my job sites anyway. Living in the boonies it's a long haul to the pit and dump sites.
I'd like to demo one vs the rock crusher from FAE. The FAE thing looks like a great tool for a CTL or skid but it's about 2600 lbs, needs high flow, and throws material. It's probably more productive but more limited in that you have to crush the material when it's laid out. Would be useful in a field or after rough grading a road but it doesn't seem as practical on a building or demo site.
mike s
Columbus Ohio
I am lining up a demo on the hog crusher and hope to get some questions answered.
AusDave
Self employed
Bucket crushers
I've started using one the these bucket crushers made by Baughans http://www.youtube.com/watch?v=PmWK0lBi2OQ
It's a 27" model I've adapted to my skidsteer but it usually would fit a 3.5 ton plus mini excavator and work like this http://www.youtube.com/watch?v=SFUGgKghJW8&feature=youtu.be
Below I have listed the four bucket crusher models and throughput per hour. Throughput per hour is determined by hydraulic flow and the type of material you are crushing. Loose, smaller material such as mixed brick & concrete will crush faster than large lumps of reinforced concrete. But if it fits in the bucket it will crush!
Excavators from 1.5 ton, 18'" - 1 to 3 ton per hour
Excavators from 3.5 ton, 27'" - 3 to 12 ton per hour
Excavators from 7.5 ton, 32" - 5 to 15 ton per hour
Excavators from 13 ton, 39" - 10 - 30 ton per hour
I have recently begun importing them into Australia and in the use I have given them so far, I've found the crusher to be very versatile especially with regard to what can be crushed. Reinforced concrete is no problem and the simple design makes it almost maintenance free. If something uncrushable like a lump of steel gets in the jaws then the jaws reverse and no damage is done.
These crushers are the lowest cost solution I have found for crushing concrete, building waste etc and they have models to fit excavators down to 1.5 tons. (18" model). Let me know if you would like any further information.
AusDave
AusDave
Self employed
Bucket Crusher
What kind of price do those buckets go for?
Hi Mike.
In Australia the 18" bucket crusher is $10,900, the 27" model $15,500, the 32" model $19,900 and the 39" model $31,900
Cost would vary a bit with regard to shipping and currency movements but this gives you a reasonable idea. The carbide tipped pins are the simple knockout and replace variety and the buckets are generally manufactured with a custom headstock to suit your excavator pin spacings & dimensions.
AusDave
Yellowdog
I inquired about the multihog at the dealer and was told they do not do well with rocks. That was disappointing. The sales rep recommended the Norco rock crusher but from the short video, it seemed to vibrate the heck out of the host machine and let a lot of stuff fall through that was bigger than the advertised 2" or minus.
I've really been thinking about some type of small crusher but if one like the hog isn't good for small rocks, then I'm left with the rock crusher attachment by FAE or similar manufacturer and I don't think it would be as versatile and will use a lot more fuel.
I was on a job site today where there was a lot of loose rock in a dry creek bed. That material would have been good to start the gravel road if it was crushed. Still looking.
mike s
Columbus Ohio
I talked with multi quip and they said that it is not a great rock only crusher but will crush some types of rocks that may get mixed in. Good to know that stuff
andrewpond
canada
Hey mike. Did u get a crusher? I am seriously interested in hog crusher. Any more feed back or info?
Nolimit
BC
I had a demo given of the hog cruhser. I had seen one in a video crushing curb concrete ( which is a very sandy mix) and it looked alright. As I am a concrete contractor I brought concrete from several different driveways we had taken out and it could barley make it through. If you are looking to crush regular rock concrete i.e.. driveways, patios, foundations, do NOT buy this attachment. If you are crushing things like cinder blocks or curbing then it would work great.
