totalloser
I just thought I'd share. For the price I have to say I was nervous. But it appears to be quite high quality. http://www.lumbersmith.com/
My original plan was to build my own to get around a design flaw in most sawmills. Most sawmills have the carriage supports right along side the center of the bandwheels, so your cutting width is just about the same as your max board size. This is a real bummer because once you shave a couple sides, the log gets a lot smaller. So a 24" sawmill cuts a 24" log into a square, and then the log is only about 16", so you wind up with a 24" sawmill that can only cut 16" boards because the carriage can only clear a 24" uncut log.
Then I found this thing, and the support arms are out at the edges of the housing. This means that you can easily square up a 24" log and cut it on a 16" saw. It actually cuts wider, but that's with slimmer boards. The drive mechanism is clever. No belts/chains. Off the shelf Honda with 6:1 gear reduction. I wish it had a clutch, though.
But for 2grand, There's nothing like it. And now that I have it, I am VERY satisfied with the quality (which worried me as I'd never heard of this company). Really slick backyard sawmill for cheap.
