Need help with PT pump on 12 cylinder Cummins
Acesneights1
Ct
We have a KTA2300 Genset from 70's here at work and the PT pump is leaking fuel and needs to be rebuilt/resealed. How difficult is this to do ? I have pulled them off 855 Small cams before and this one looks the same but there is no air compressor. The PT pump is driven by an old Woodward hydraulic governor(basically in place of the air compressor) . I know there is no timing involved with these but I am not sure if I will have to mess with the governor once the new pump is in or this one rebuilt. Also it looks very tight to get to one of the 4 bigger 12 pt bolts (bottom mounting inside towards motor). If I can't get that bolt out then I would assume I have to pull the Woodward Governor and PT all in one ? Has anyone done this job ?
Acesneights1
Ct
I need to clarify, I only need to pull the pump and reinstall it. We will send it out for rebuild.
Acesneights1
Ct
I am hoping these 4 bolts are all I need to remove however inside bottom looks very tight.
Acesneights1
Ct
For reference this is the whole unit. 12 cyl Cummins circa 1977. about 200 hrs.
kshansen
Central New York, USA
Or with a little help from a heating tip you can make your own. Might want to hit Harbor Fright and buy a couple 7/16 wrenches to work with.
Zewnten
Earth
Site called apex industries sells a lot of the cummins specialty tools, or at least gives you an idea for what you need to fab.
