Diggedirt
Hello all,
I have a little noise at one of my Aux. hyd. couplers that has me stumped. The attachment is a skid steer Beak which has one double action cylinder on it. The first time I open the jaw (withdraw the cylinder) it makes no noise but a noise happens every time I open the jaw after that. The sound is similar to that which is made when there is air in the lines but I have used a loop hose to remove any air trapped in the lines. I had a small drip at the coupler and suspected it might be drawing air as fluid is withdrawn but I have tightened the connection and the noise still remains.
It seems isolated to the coupler. I did remove both couplers, connected the two together and ran them through the parts washer to clean them out. The only thing I have not done is swap the coupler with another one to see if the noise stops.
The strange part is that this all started when I switched the couplers to change how the attachment functioned in relation to the control buttons. I did not notice any noise before I swapped them.
Any ideas?
Thanks in advance.
Any ideas?
Thanks in advance.
