justafarmer
Have a waste oil system on my service truck. Just your run-of-the-mill diaphram pump with a 4 way selector valve so I can pump or suck onto the truck. Looking to get a hose reel. Can I use a single braid 1500 psi hydraulic hose on the reel? I know it wont be a issue with the pressure because it will only pump 100 psi or less but just wondering about the suction end of it. Common sense tells me that it should hold up fine. What are you guys finding?
