I am hoping someone can give me some guidance on my problem. A few years back I came across a couple 644-A's somewhat cheap and me not knowing better, bought them. I guess thats not really fair since I have used them enough to justify buying them. However, I have ran into some trans/eng problems so I took the worse one out of service to use for parts. To make a long story a little shorter, after rebuilding the engine and replacing the crank I developed an engine oil leak in the flywheel housing. Its hard to tell exactly where the leak is coming from since the flywheel slings it all over the place. However there doesn't appear to be too many places for it to leak. I have replaced the rear main seal 4 times now, including the last time using the expensive install tool. So I am somewhat convinced its not the rear main seal. However I can start the engine without the housing installed, and the oil gets slinged off the backside of the flywheel. Does anyone have any ideas what this might be? Anyone heard of a defective crankshaft that leaks oil like this? I am starting to run out of ideas on this machine. On the plus side though I now have experience taking the machine down to the flywheel and can tear it down in less than a hour now. Thats about the only good thing I can come up with so far. Can anyone help me with this antique?
