Oil ?
PSDF350
Richmond NH
Went to change oil in my Cat skidder today (3304 motor). So I went to napa to get oil. Guy gave me some Valvoline engine oil and I didn't notice it is not specific for diesel motor. It was on shelve above the synthetic for diesel thats why I didn't notice. Anyway my question is should I be using a oil that is made specificly for diesel or is what I bought fine?
Jeff D.
MN.
PSDF350,IMO I woudn't use it.One oil change with it probably wouldn't do any detrimental damage to the motor,but it wouldn't have the same additives as a diesel engine oil.
I believe that diesel oil has an additive to control soot,which isn't a problem in gas motors.There may be other additives that it would lack also,and may have some which wouldn't be needed.
Better to be safe than sorry,since you've caught the mistake before it went in.
PSDF350
Richmond NH
Thanks Jeff. Thats what I was thinking. Thats why I didn't finish oil change. Figuired i'd ask here first.thats why she is sitting out there right now oilless. But this stuff does have the soot additive.
Bob Horrell
Charter Member
Acton, CA
Owner/Operator grading business
Check on the label for the letters CF, CG, CH, or CI. The "C" stands for compression engine (diesel). If any of the above letters are on the label you are good to go. If not, don't use it.
PSDF350
Richmond NH
Thanks Bob. I didn't realise the C stood for combustion. On bottle it is API services CI-4 plus, CI-4, CF/SL. I get confused (easly) with all these desiginations. One problem is my op manual was printed in 90 so is a bit out of date on it's secification. Which are API CD/SD, CD/SE, CD/Sf, CD/SG, or CD. But after reading bottle it does seem to have what it is supposed to. Just to make sure I am going to call Cat in the morning.
digger242j
Southwestern PA
Self employed excavator
dang... I'm still learning something new every day... :)
So, on the label when it says "API service SI, SJ, SH", what does the "S" stand for?
Jeff D.
MN.
Where's Salesrep when ya need him??:bouncegri
He'd know.
I've heard some oils can be used in both diesel and gas motors.They must have enough additives too cover both engines needs.I believe Rotella is one of them,depending on the API ratings for the engine ofcourse.
PSDF350
Richmond NH
He'd know.
Thats what this oil is supposed to be. It is all fleet plus. For fleets of mixed gas/diesel motors.
digger242j
Southwestern PA
Diesel oils can be used in gas engines, but gas oil shouldn't be used in diesels.
Now, I was told, by a diesel truck mechanic, (and admitedly, this was 20 years ago, so oils may have changed since then), that you should not use diesel engine oil in your gas engines either. Supposedly something about the detergency being too much for the gas engines. He said that you maybe could add one as the last quart before an oil change, and it would help clean the engine out, but otherwise it would take out your piston rings.
Yeah--Where's Salesrep when you need him? :)
Grader4me
New Brunswick, Canada
The "S" stands for spark ignition. I took the easy way....googled for the answer.:wink2
PSDF350
Richmond NH
I called cat today to make sure. Service guy said no problem. He only wanted to know what weight oil. When I told him, he said that will be fine. So I put it in. It is made for both though, so it should be fine. But I think next time I will make sure it is only for diesel.
PSDF350
Richmond NH
:notworthy
digger242j said:
And you didn't have to admit that either. :)
Just goes to show the man has integrity. So many these days know everything or at the least try to make you think they do.
Grader4me
PSDF350 said:
:notworthy
Thanks! When I have chances I will share what I do know. Things that I am not sure of I will openly admit and not try to bull****:yup Always been like that.:)
I will admit after reading the many posts over the months, the knowledge and wisdom of the members of this forum is very impressive. Glad to be a part:notworthy
