Picked up a CL deal, today...
DIYDAVE
MD
Saw a good deal on craigs list, only problem was the where. Anyway called the feller up, he said call me around 2P, so I piddled the mornin away, blowed alla the grass offa the mower, changed the blades, had more time, so's I started workin on the trailer tailgate, expanded metal, extra thin, needed a patch. Remembered I hadda aluminum diamond plate tailgate cover layin around, it were just long enough for the patch, so's I cut that up, then proceeded to cut the bent up chicken wire offa the tailgate, eat lunch, screw the patch in place with 13 screws, all by 1:15. Walked up to t'other truck, popped the hood, had just putta quart of oil in, when the feller calls me up, says he's home, come on over. So I head swampward, through DC, into Annendale, VA. 45 minute trip each way only rook an hour, each way...
Anyway, here's what I got:
www.homedepot.com/p/RYOBI-ONE-HP-18V-Brushless-Cordless-7-1-4-in-Circular-Saw-Tool-Only-PBLCS300B/314109411?source=shoppingads&locale=en-US&&mtc=Shopping-RM-F_DYNM-G-D25T-025_009_PORT_POWER-RYOBI-NA-NA-SMART-NA-RMP-MK491413300_9016797488_FY22_3338&cm_mmc=Shopping-RM-F_DYNM-G-D25T-025_009_PORT_POWER-RYOBI-NA-NA-SMART-NA-RMP-MK491413300_9016797488_FY22_3338-71700000090162140-58700007647880391-92700069096055305&gclid=Cj0KCQjwpcOTBhCZARIsAEAYLuWotWt0bMa85cstTw81_mcQvIhm02--XirPgktRy2NGnfiqzKXo0lgaAgtFEALw_wcB&gclsrc=aw.ds
Also got 2 6 amp- hour battries with it, and a charger!
Also got one of these:
www.homedepot.com/p/RYOBI-ONE-18V-Cordless-1-4-Sheet-Sander-Tool-Only-with-Dust-Bag-and-Extra-9-Piece-1-4-Sheet-Sand-Paper-Assortment-Set-P440-A19901/316650390?g_store=&source=shoppingads&locale=en-US&&mtc=Shopping-RM-F_DYNM-G-D25T-025_009_PORT_POWER-RYOBI-NA-NA-SMART-NA-RMP-MK491413300_9016797488_FY22_3338&cm_mmc=Shopping-RM-F_DYNM-G-D25T-025_009_PORT_POWER-RYOBI-NA-NA-SMART-NA-RMP-MK491413300_9016797488_FY22_3338-71700000090162140-58700007647880391-92700069096055305&gclid=Cj0KCQjwpcOTBhCZARIsAEAYLuUxTi_BIWpTbDQq9s7XgszaH4myga9Pjip3TcxZxsLcOaqrUMZnSRgaAiQ6EALw_wcB&gclsrc=aw.ds
Ain't gonna break down the other 8 or so other tools other than to say, all Ryobi, all near new, sawzall, drill, 1/4 impact driver, 5-1/2 circular saw, 3 oscillating cutters, and some more various batteries and chargers... anyone wanna guess the price is right, style? Come on down!
DIYDAVE
MD
No Guesse$? Also in this batch was a 18 volt weed whacker, wimpy lil thing, uses .60 string, about 3-4' long, but I wasn't gonna refuse it. Tried it out, put it on the floor of the Altoz, when I mow the road frontage, cause I have 5 phone poles that never get trimmed around, figgered I'd give it a try. Wimpy, my a$$! that lil thing is handier than a shirt pocket, I can use it while sittin in the seat of the Altoz! It'll chew up anything smaller than about 1/2" in diameter, I even chewed up some cherry trees that had sprouted by the poles!;)
John C.
I wonder if there is an update to allow using a lithium battery in my old nickel metal hydride drive drill? The old batteries are more than $100 apiece but there are deals on the newer lithium batteries and chargers.
JD955SC
The South
They make much better ones than the ultra cheap Ryobi 18V ones.
ryobi makes a much better 18V one and then they make 40V ones that are extremely good.
I have the 40V brushless weed eater and blower combo that’s the best they make (well short of the carbon fiber shaft one that was almost identical but $50 more). The power from this weedeater is the exact same as a commercial gas one and the feed head is a good, very easy to load bump head as opposed to the cheap auto feed junk that slings your line out. You can also separate it at the shaft and use a pole saw or edger attachment instead.
DIYDAVE
MD
My main concern was that it was cheap, fits on the floor of the altoz, and uses batteries that I already have...;)
ianjoub
Homosassa, FL USA
I purchased an adapter that allowed me to put 20v batteries in my old 18v Dewalt stuff, was pretty cheap.
colson04
Delton, Michigan
I did the same, though I found the 18v drills don't compare to the new brushless models. I burned up one 18v drill, almost have the second one cooked now. It has a hot, electrical type smell when operating now.
ianjoub
Homosassa, FL USA
I have changed over to all 20v stuff as well. I have tried, without success, to give away the 18v stuff and the adapter. no one wants it for free!
John C.
How would I look up that adapter. I've got one drill and a jig saw that is battery and I love using them both. The drill is Ryobi and the saw is Dewalt. Both use the older nickel metal batteries. Do I have to buy both the charger and the battery to use the lithium products.
JD955SC
The South
Yes, generally ltithium batteries will require a compatible charger.
honestly with the prices of a couple of batteries, charger, and adapter you are better off replacing with new.
John C.
I use the drill a lot more than the saw and I have a pretty new battery in the saw. The battery in the drill is about six or so years old and will need to be replaced in the not distant future.
ianjoub
Homosassa, FL USA
John C.
I see what you mean, it's cheaper to buy a new tool or just buy another 18V Nickel battery.
Thanks for the thoughts!
DIYDAVE
MD
Don't know anything about the Dewalt side, but on the Ryobi, if you get a new bat, you need a new charger. Check out the HD site, its near father's day, gots lotsa specials on. I think if you buy 2 batteries, you get a free tool of your choice. If not, keep lookin, lotsa packages and specials...;)
JD955SC
The South
Id get a new drill kit then, and now is the good time for it with Father’s Day sales. Just don’t buy the cheapest kits of a given brand. Go for the more premium brushless option of a given brand.
