Eric a1cnc
I bought this set at harbor freight cheap as they are discontinuing it. It has the pencil injector adapter I needed for my case 188 engine but It doesn't seem to work right. When turning the engine over it would build pressure on the 1st compression stroke but the pressure would drop immediately. I thought it was the cyylinder first untill I did the finger over the hole test and it is fine. I noticed it has no check valve only the pressure release valve. I tried to pull the pressure relief valve out to try to clean / fix it but it was loctited in and the metal was so thin it snapped right off.
My question here is, How is this supposed to work without a checkvalve?
I will call pittsburgh on monday to see about a new pressure relief valve.
https://www.ebay.com/p/11024420141
