Midnightmoon
Got one of these for Christmas
https://www.amazon.com/pokitMeter-multimeter-oscilloscope-logger-White/dp/B07PR97N8B
It's a pretty handy little tool for under 100 I asked santa for it for the logging ability and the oscilloscope. I use my fluke meter for everything but watching for voltage drops while testing things can be tricky. I can hook this up set the app on my phone to start logging and look back to see if I had a voltage drop. Works great for that. I've also used the oscilloscope just to see how it works and save some logs of working can systems so when I have a problem I can compare it to a known good communication. It has some good functions not as many as my fluke comes with an extra fuse. The only downside is the app is a little tricky to use u till you get it figured out and i made some jumpers to use all my electrical connectors with it. The ones it comes with are a bit limited. I was using the oscilloscope from 40' away not bad for blue tooth. I'm looking forward to my next can error code to come into the shop. I know snap on makes a similar remote system but that's about 350. This one fits in your pocket and is so far is as accurate as my fluke.
