Early 613 Caterpillar 1976-77. Oil from the transmission is leaking into the bell housing of the engine and coming out the starter under heavy load. There are hydraulic lines from the transmission going into the back of the bell housing in front of the two pumps. Where could the oil be leaking from? Pulling the inspection cover off the bottom of the housing and found it was filled with oil.
