kshansen
- Joined
- Mar 11, 2012
- Messages
- 11,173
- Location
- Central New York, USA
- Occupation
- Retired Mechanic in Stone Quarry
We have had this truck for just over one year 1035 hours on meter!
Yesterday driver shut it down to fuel at the end of shift and when he tried to restart no crank.
Tried jumping with plug in jumpers and rear disconnect switch off same problem. Some lights woul;d work with key switch off but go out with it turned on.
Started checking the wires at the front bumper breakers with eky off had 25 volts, turn key on droped to 5.6 volts. Checking going back to starter and still very low volts. Decided to check out grounds, all looked good but when I checked grounding through the disconnect switch not good! Turns out the master disconnect swith was bad.
This one is the type with the disconnect switch and the jump start pug assembly all molded togeather. Parts book shows the disconnect switch to be separate part, same old 7N0718 but there is no way to disassemble ours. Sticker on assembly has the 237-7602 number but with a /05 after the part number.
I'll know better when the part comes in and I get to put it in on Monday, if the swich is replaceable on the new one.
We ahve some old machines that are over 30 years old that problably never had a switch replaced and this one just had it's 1,000 service and it's failed already hope this does not say anything about the rest of the wiring!
