Rexroth 160cc motor rotating group rebuild
partsandservice
Georgia
Note the position of the bearings and the bevel on the spacer, which must face the larger bearing for cage clearance.
partsandservice
Georgia
completed bearing installation. Then piston installation. Spring in center should be greased to hold in place when loading barrel.
partsandservice
Georgia
Next heat motor housing and install rotating group.
partsandservice
Georgia
Grease to hold lens to head. Install oring. Then install bolts by hand till head is all the way down then tighten with impact.
partsandservice
Georgia
Check for smooth rotation. Install shaft seal with spacer and snap ring. I like to install seal then spacer and tap spacer untill ther is enough room to install snap ring then tap whole assembly till snap ring locks in. that way I know the seal is not in to deep. Hope everyone has a good year .
Huntoon
California
Sales Engineer. I design OEM tracked undercarriage
:notworthy Awesome job. Thank you for documenting!
