d9gdon
That's a really well kept 7F.
That 7 is a real creampuff,a pleasure to work on compared to the late model Bulldozers.That's a really well kept 7F.
Here's a nice old D7F resealing cylinders. View attachment 281241 View attachment 281239 View attachment 281238 View attachment 281240
Depends what STOODY product you are using, I use STOODY 101HC 1/16" with 75-25 gas@26v, 200a, dc reverse. If it was
.045 I would start at 22v 150a wire speed you will have to play with.
Good luck with it.
SSSHH! If someone finds out about what a grease gun can do Tom will be out of work!Those machines look too new to need line boring. We're they never greased?
So rather than lack of grease it is the excess clearances both letting grit get in to act as a grinding compound along with the slop hammering the metal out?The 135 has 5000 hours on it and we'll lubricated, the 85 has 1180 hours on it and also well lubricated, these things start out with excessive clearances and poorly finished parts = prematurely loose machines.
