Has anybody ever taken the cab off a Komatsu PC75?
Any suggestions or ideas as to how easy it is?
High trailer, low bridge and provided the boom is down real low and you have a good speed its quite easy.
The hard part is getting it back on again afterwards, they just dont line up properly.
Seriously, I have never done it, with or without a bridge
but if you think about it logically it wont be that difficult.
I would expect Servo pipes will be routed to avoid conflict and the same with the wiring harness.
There are probably 4 threaded holes in the roof or around the top of it so that lugs can be screwed in.
I would expect 4 bolts from underneath to hold it in place.
Once you have found the lifting points, then find the securing bolts BEFORE you get too involved in a lifting frame/device make sure you have access to the bolts. You may need to slew the house between the tracks, thats a PITA if you already have a lift set up :Banghead
Once you are happy that the securing bolts are out and you start to lift check and double check that things are clear, not caught or ripping themselves apart.
There are a couple of Komatsu guys on here that I am sure will give you a help if anything is not straight forward.
Dont forget the pictures
