My TD8E has a Bosch VA4/10H 1250 CR90 that needs rebuilding. Local shop says parts may not be available and may be $900 to rebuild. Engine is DT239. I found a good VA4/10H 1250 CR 89/1 off or a TD7E with a D239 engine. It looks like the same pump except for linkage that I could swap from the bad pump. Question is can anyone verify that the pump off of the TD7 will work on the TD8. Thanks
