from what i've seen so far with the EFI engines that bobcat is using, the doosan in the mid frame machine has been more trouble free than the kubota that was used in the large frame machines. the kubota has DPF on it, and operators like to override the regen.
eventually leads to a plugged DPF, and 75% derate, neccesitateing a service regen.
biggest issues are in extreme cold weather running #2 fuel. all the EFI engines use a 2 micron fuel filter that doesnt "like" cold fuel.
using a 50/50 mix of #2 & #1 fuel helps the fuel flow through the filter.
bobcat has added a fuel warming curcuit to bypass the fuel cooler in cold weather on the doosan engines.
:drinkup
I'd take a DPF over the Doosan solution anyday from what I've heard. Been dealing with DPF's on stuff for awhile and while it sounds like a bad idea, they haven't been. Early ones were, but they're pretty refined now. Bad operators can still cause issues as you elude to. Why are the operators ignoring the regen? Are some brands still unable to accomplish a working regen? The Cat's using the 3.3 Kubota with DPF have a few levels, first they will flash that it needs to regen and you simply run the machine above half throttle while continuing to work, or let it idle and walk away, after a short time period it will do it on its own. The next stage is a parked regen, if you continually ignore the warnings leading up to it. If you keep ignoring it, eventually you will get shut down and need a service tech to do one. It takes a lot to get to that stage though. Ours is over 400hrs now with operators that would not understand the regen process at all. None have asked about the light either so either its asking and they just ignore it, or it hasn't needed to yet. I find it pretty unlikely in 400hrs it hasn't needed to. Other's and myself do run it from time to time and haven't noticed regen warnings either. It does not have a way to see the number of regens in the display. Of course you also always have the passive regens where you work it hard enough to create enough heat for a regen without any assistance. We don't work the machine very hard but it sits in solid dust, so it does make some heat from time to time.
The DPF is not the big mean guy everyone seems to make it out to be.
Never had any fuel issues on our Kubota equipped machine either, we avoid blending #1 until sub zero temps. Additives put in by supplier keep issues away until then.
