Tinkerer
Can anyone explain why a flex plate would turn into such a total disaster ? I removed the engine in my Case tractor/loader/backhoe for a major overhaul and this what I found. There was a lot of rust in the flywheel hub and on the converter nose.
I had no idea that the flex plate was failing. The machine still ran OK with no vibration or noise. If you look closely at the metal around the bolt holes they are cracked to the point of breaking off like the others that are broken.
