With reference to Nige’s comment on checking the oil in the rollers.
I learned many years ago that rollers needed to be handled more carefully until they are fitted onto the trackframe than you might think.
In my teenage days,I recall pulling up to my first D8 to do the bottom rollers one Saturday afternoon with a trailer with pallets of new Berco bottom D8 rollers.I dropped the side of the trailer down and proceeded the push them off the pallet and straight on to the haul road.It seems obvious now,but wasn’t to me then as a newbie.I soon got my ears clipped by the fitter that was helping me.I was told to unload them gently down,then check every plug to see if they’d been filled from the factory as this small detail was often overlooked.
Since then,I’ve allways checked rollers and idlers before fitting and only found a handful of empty ones.
You say the rollers are Trek and not Cat like your track groups.This is no big problem,but I’d certainly do as Nige says and check them all along with idlers.
If oil runs out,it’s ok.If it doesn’t you’ll want an old volume bucket.If you don’t have one,fill your oil can up and squirt it in the old fashioned way.
Be aware that on hot days,they may vacuumed and give a misleading level
