Correct-either has a spring brake valve or just a QR-1.Has maxi's so R6 just service side?
What's a 396.2 card?
That's true--However CDL part of air brake inspection does not qualify for adjusting orNothing mention in the reference as being a "card." Just having a record that a mechanic has been trained.
You don't have many posts, are you some kind of lawyer?Thanks for posting the link for others.
There is no such thing as a CARD. There is no card that needs to be carried or produced. There is no certifying agency for issuing a card. The word "card" does not appear in that section.
If you worked somewhere that issued a card, that is fine, but the DOT has nothing to do with it.
If you don't have a CDL without the L restriction, then the shop you work at must maintain some record that you are qualified, but that is not required to be a card.
Again, 396.25(e) states that a carrier or intermodal carrier is not required to MAINTAIN any records of qualification for a CDL holder that doesn't have an airbrake restriction.
396.25(d) states the requirements. There is no requirement for training, although it can be one avenue to satisfying 396.25(d)(3) as outlined in 396.25(d)(3)(i) and (ii).
To be qualified, you have to Understand, be Knowledgeable and have Experience. In essence, a mechanic can self-certify.
Finally, the title of 396.25 is Qualifications of brake inspectors. The section makes no differentiation between an inspector and a mechanic. If you can qualify under this section, you can do work on the brakes.
Lawyers will have a field day anyway and a nothing in 396.25 will prevent that.
Agency? I think your trying your best to be a newcomer smart ass.Cool. What agency issued it?
Hey Truck Shop,That's true--However CDL part of air brake inspection does not qualify for adjusting or
repair of air brake system. The card is proof to DOT that a person can adjust or repair
air brake system by having training from a manufacture of air brakes. A driver can look/
inspect but that's about it. Especially if there's a accident and it enters the court room,
lawyers will have a field day. It enters the area of is the driver a mechanic also-probably
not.
There two federal regs, one contradicts the other. There is 396.25 and a appendage CFR49 that goesHey TruckStop,
I was reading your posts and had a couple of questions. I have a truck that has manual slack adjusters. Does that mean that I am not allowed to adjust my own truck and trailer brakes?
Also, I removed all wheels and brake assemblies and installed new drums, pads, brake hardware and slack adjuster bushings which took me a couple of days between driving around and taking back drums once I figured out they sold me a wrong sized set. Sounds like that is not ok?
That truck have engine brakes? jake. Might need new slack adjusters if the lock doesn't pop outI can tell you this, from my short experience with only one truck.. The brakes can loose power during just a full day's use and I have had to stop and adjust during a work day. I have 3 times had my brakes go soft and for those that have not experienced it, once you can not stop a load and it is pushing you down the road, you will do what I now do stop in the first place you can and tighten the brakes.
No engine brakes. I have wondered how long a break adjustment should last. I believe the locks are popping back out. On some of the air brake chambers you can see where the rods have worn the edge of the chambers from touching when they push out too far.That truck have engine brakes? jake. Might need new slack adjusters if the lock doesn't pop out
at hexhead adjuster those will back off each time brakes are applied.
