Leon Phelps
hello,
I have a case mini-sneaker. It is supposed to be able to pull 2" pipe up to 1000'. I was wondering the type of pipe to use, poly or PVC? I need to make a 300' run with 3 coax (video surveillance), one power (12/3) and water to the same location. Was thinking of putting an ethernet in there also. I could get away with 1" for the water poly is fine. As for the rest, I am unsure what to do since fishes are rarely more than 250 feet. I have heard of the vacuum trick, but need to find the pipe and get it pulled first.
Also, should I just use the snake type grip on the plow blade?
