Looking for opinions on an A25C gearbox. GKN manufactured gearbox.
Dumper will go into forward and reverse but will not shift up through the gears. Box has had the oil removed, although dirty oil no metallic contamination found. Oil filter cleaned and re-fitted. No difference. However on the over run going down hill it WILL shift up through the gearbox.
Local plant company insists on wanting to fit a reconditioned gearbox they have on the shelf @ £7500 ($11,500).
This gearbox must have been used in different aplications. £7500 seems a lot of money when our 'knackered' gearbox is going to be an exchange unit. What could possibly cost £7500 inside that gearbox!
A few thoughts of the top of my head: My first thought is there must be a valve body inside the gearbox that controls the clutch packs through solenoid valves and pressure. This I assume can be removed/reconditioned. I know it is not a lot of money to have an automotive valve body reconditioned.
Any ideals welcome!!
