Brent Norris
Im located north of Beaumont in Saratoga, Tx. Im trying to find someone other than Romco to work on A volvo excavator with cpu problems. Anyone with any knowledge or direction?
thanks
thanks
Im having cpu failure and the unit will not fire up now. i went to switch power to limp mode and that doesnt work either :/What is the issue that you are having?
I will check that and update asap.That's a 210C , the Bs were problematic. Behind the cab, in your fuse box, there should be a relay RE 3301 if I remember correctly. Please swap that one with one for horn. In the meantime I will see if I can find better information
Do they all have the kill switch? I have had mine a long time and had no idea there was one. Where is it at?
