kmbrad
Hi
My L70 loader has the TD45B engine. The other day it started to lose power as if it was low on fuel. Filled her up as she was getting low but problem stayed.
It’s fuel related, seems to rev ok in neutral, but when it’s under load and your travelling and start to load bucket up it’s starts to lose power. When it starts to die you can kick the throttle and it comes back to life. Also noticed it won’t start now unless your on the throttle.
Throttle linkeage looks ok, put new fuel filters on, changed lift pump, still the same. May change fuel line from tank to filter next incase it’s pulling in air.
We noticed the Injector pump was loose the other day, tightened up ok. All other feed pipes etc are ok, and it’s not leaking diesel.
Does anyone have a clue where to start?
Cheers
Karl
Cheers
Karl
