iknow people he has for sale from jeanmauriceboutin@videotron.ca
I've owned and operated a TD5 , very capable little dozer . New in 1963 mine in 1980 . OC3 does not even compare to either the TD5 or the petrol version you are looking at . The steering is quite modern for the age of those dozers being the clutch on the first part of the leaver pull then engaging the brake further back . It has to be adjusted just right or will cause wear to bot the brake and the clutch . These little Inters are easy to work with and repair . Main clutch was a foot pedal on mine . What it come to is whats left in the tracks . The T340 would be bigger than the OC4 by 10 HP , a lot when at that size .Thanks TomA. Why is a OC4 better? Im watching for one of those also.
