Who uses a skid steer only at home?
TALLRICK
florida
I have found my old M610 to be the best garden tractor. Is there anyone else out there who uses a skid loader for non-commercial use only? It sure seems like a nice way for an old skid steer to retire and get more out of its life. There comes a time when a machine can no longer be reliable enough to earn money out on the jobsite, but a valuable helper around the yard.
itsgottobegreen
Maryland
I guess thats what you could call my m600. Its suppost to be my shop only machine. But my grandfather has it and won't give it back. He really needs it more than I do because of his back.
hilbile
Graf Iowa
Manual labor
all of the machines we have owned were for our personal use. starting with a used M700 bobcat, now our current 743. which is used for plowin snow and rippin up the garden, along with everything else u can think of, like today we are useing it to put shingles up on our neighbors roof. our other two, another 743 and a M610 were sold after we got them fixed and running
Coastal
BC, Canada
Well, mine does both. I couldnt imagine not having bobcats and excavators around the house. Today im doing a garbage run, so i need to load up my roll off with junk using my excavator. I guess thats the perks of owning stuff. :D
johnstra
Colorado
I'll be using mine at home only. It will be for clearing snow. Now if I can just figure out which one to get.
-john
TALLRICK
florida
-john
The ones we get seem to be the ones that we find. Affordable, not too much to get going and simple is always a plus! Still trying to figure out that concept of snow!
StPat
AK/NM
Hi all, new guy here. I bought a 753 Bobcat 5 years ago and took it up to Alaska to use around my son and I's portable sawmill. That has to be one of the best pieces of machinery I have ever had. I'd like to get another one to keep on my place in NM, have a small pecan orchard and am always wanting tio move stuff. Was wondering if anyone has a cross refrence from the old model numbers (743, 753 863 etc) to the new numbers? Most of the machines I see are the newer ones and I don't what the hell I'm looking at. Great forum, we're looking to buy a Hitachi D60 excavator and a Komatsu 20 or 21 dozer for use in Alaska. Any coments or suggestions are welcome.
Cheers
Patrick
Countryboy
Georgia
Load Out Tech. / Heavy Equipment Operator / Locomo
Welcome to HEF StPat! :drinkup
7775deere
Alberta Canada
We use our bobcat around the farm all the time, its pretty handy to have, dont always have to get the tractor for small loader work.
Cowboy
Illinois
I use my Gehl 4615 all the time around the farm. We use it for doing everything from cleaning stalls to hanging deer. Most usefull tool around in my book. Don't know what I would do without it.
gypsycatfish
north east
I just bought a bobcat 873 and as soon as I figure out why it seems to not get fuel I plan to put it to use building my house.
Countryboy
Georgia
Welcome to HEF gypsycatfish! :drinkup
rick342
milford, mass.
Newbie!! Bobcat 610
Hi guys, I just found this forum and very glad I did. I use my 610 at home only and have owned it for abut 15 years. It has a Wisconsin air cooled engine and runs great. But recently, after running for about a half hour or so it will just shut off, and will not restart for about 3 min. this will continue all day!! But always will restart after the 3 min. (rest)??? any ideas??
Thanks so much...........Rick:Banghead
Countryboy
Georgia
Welcome to HEF rick342! :drinkup
Steve Frazier
Founder
Staff member
LaGrangeville, N.Y.
What type of ignition does it have, magneto or coil? It could be the coil overheating if you have one.
Another possibility is vapor lock, or gas boiling in the line. Does the gas line pass close to the exhaust anywhere?
There could also be an obstruction in the fuel line somewhere or in the fuel filter.
Do you have any more details on what's happening when it shuts down? Does it slowly sputter to a stop or shut off like with the key?
jhill
Thumb of MI
My JD skidsteer has several pressure sensors that are tied into the fuel cut off switch. These are hydraulic feed pressure, system pressure and others.
If they sense low pressure they shut off the fuel to prevent system damage. Recently 1 went bad causing the machine to shut down after a couple minutes running. Could you have something like this?.
Jerry
rick342
milford, mass.
Thanks for quick response guys.. It does have a coil, The fuel lines are not too close to the exhaust, and when it shuts off its like to turn the key off, no sputter at all...This only happens after the machine has been operating for 1/2 to 1 hr, and then will continue to do it. The level of gas in the tank makes no difference... Thanks again...Rick:beatsme
TALLRICK
florida
I also have an M-610. Do you have the Wisconsin engine? I had the same "shut down" issue and it was due to a faulty ballast resistor. If you use a coil with an external resistor make sure it is good. Otherwise it heats up and cuts out, or the resistor is shorted and the coil overheats. The points also fail quickly in such a configuration. When it shuts down pull the coil wire and crank to check for spark.
rick342
milford, mass.
Great idea, I'll check that out soon.. Yes it is a Wisconsin gas engine, Where will I find the resistor?? Thanks.....Rick:notworthy
TALLRICK
florida
The electrical system is pretty simple, all power comes from the positive battery cable connected to the starter. A main resistor is located inside the gauge pod on the right side as you sit in the seat. A bundle of wires goes from there to the mechanical voltage regulator. A plug separates the engine area harness from the gauge pod area. Some of the later models to have an engine oil switch that can shut down the engine upon lack of oil pressure, but that is a bit more unusual. Do you have a manual?
