Wirtgen w2000
Ben Derstein
Pa
Anybody ever rebuild/seal a drive coupling in one of these. Looking for the procedure to take apart.
Tom3697
United Kingdom
Yes, it is possible to rebuild or seal a drive coupling in many machines. Here is quick steps:
Locate the Couple: Find where it is located between the motor and the driven part.
Safety First: Turn off the machine and disconnect it from power.
Access and Inspect: Remove covers to access the coupling. check for damage.
Disassemble: Follow the manufacturer's instructions to take it apart.
Replace seals and parts: If needed, replace seals or damaged components with recommended parts.
Reassemble: Put everything back together carefully.
Test and Check: Turn the machine on and ensure the coupling works without leaks or strange noises.
Document: Keep track of what you've done for future reference.
